In Tally.ERP 9, you can record a journal voucher to account for the reversal of input tax.
To create a journal voucher of reversal of input tax
N ote: You can create a journal voucher from Gateway of Tally > Display > Statutory Reports > VAT > select the VAT or CST form.
2. Click J : Stat Adjustment to enable required options in the Stat Adjustment Details screen.
o Select Type of duty/tax as VAT .
o Select Reversal of Input Tax as Nature of adjustment .
o Select Excess Claimed Earlier in the Additional Details field. The Stat Adjustment Details screen appears as shown below:
o Press Enter to save, and return to the voucher.
3. Debit the expense ledger, and enter the value.
4. Credit the VAT ledger.
o Enter the Rate , and Assessable Value in the VAT Details screen.
5. Press Enter to save.
'Reversing Input Tax (Maharashtra)' has been shared with
