https://help.tallysolutions.com/docs/te9rel54/sync/How_to_synchronise_data.htm
Configuring Data Synchronisation
You can synchronise data on-demand or online using the Tally.NET Server or Private Network (IP address). A valid TSS is required to synchronise data using Tally.NET Server, for both online and on-demand options.
Steps to synchronise data
To synchronise data
1.     Configure Server and Client Companies.
2.     Configure TSS feature on the Server Company and Client Company.
3.     Connect Server Company to Tally.NET Server.
4.     Create Sync Rule on Client Company.
5.     Send the rule by synchronising to the Server Company.
6.     Activate Sync Rule on Server Company.
7.     Synchronise Data
Note: To synchronise in a private network, use your static IP address, and port number details on which Tally.ERP 9 is running.
Steps for Synchronisation using Tally.NET Server and Private network
See also
On-demand Synchronisation
Online Synchronisation
