https://help.tallysolutions.com/docs/te9rel54/Tax_India/VAT/andhra_pradesh/Input_Tax_Adj_URDs_Pur.htm
Input Tax Adjustment for Purchases from URDs (Andhra Pradesh)
You can record input tax adjustment for purchases from unregistered dealers by creating a journal voucher.
To record journal entry to account tax on URD Purchase
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment.
3.     Select the option VAT in the field Type of duty/tax.
4.     Select the option Tax on URD Purchase in the Nature of adjustment field.
5.     Press Enter to return to voucher.
6.     Debit a VAT ledger created under the Duties and Taxes by enabling the option Use for Purchase Tax? after selecting Type of duty/tax as VAT.
o      Enter the rate and assessable value in the VAT Details screen.
o      Press Ctrl + A to return to the voucher creation screen.
7.     Credit a ledger created under Current Assets, and enter the value in the Amount field. The completed screen appears as shown below:
8.     Press Enter to save.
