To capture increase in input tax, you can create a journal voucher with Increasing Input Tax as the nature of adjustment.
To create journal voucher for tax credit on opening stock
2. Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
In the Stat Adjustment Details screen,
o Select the option Increasing Input Tax in the Nature of adjustment field.
o Press Enter to save and return to voucher screen.
3. Debit the input VAT ledger.
o Enter the Rate, Assessable Value and Schedule Serial No., and select the Schedule Name in the VAT Details screen.
4. Enter the amount in Debit column.
5. Credit the purchase ledger.
o Select the Name of Item and enter the Amount in the Inventory Allocations screen.
6. Press Enter to save.
'Increase in Input Tax (Rajasthan)' has been shared with
