Exporting Data
https://help.tallysolutions.com/docs/te9rel54/Data_Management/Export_of_Data_Intro.htm
Exporting Data
Data can be exported from Tally.ERP 9 for many reasons such as for use in a third-party application, for filing returns, and so on.
You can export data in 6 different formats:
●      ASCII (Comma delimited)
●      Excel (Spreadsheet)
●      HTML (web-publishing)
●      JPEG (Image)
●      PDF (Portable Document Format)
●      XML (data interchange)
Click the following links for more information:
Export Formats
Exporting Masters
Exporting Vouchers
Exporting Reports
