Like provident fund, ESI amounts are calculated separately. However, you need to pay the amount using a single payment voucher.
To process the Employer ESI Contribution
1. Go to Gateway of Tally > Payroll Vouchers > Ctrl + F4: Payroll.
2. Press F2 to change the Voucher Date.
3. Click A: Payroll Auto Fill.
4. Select the required process in Process for field.
5. Enter the From and To date.
6. Select the appropriate Employee Category.
7. Select the Employee/Group from the List of Employees/Group.
8. Select the appropriate Payroll Ledger from the List of Ledger Accounts.
9. Press Enter to go to Payroll Voucher Creation screen.
10. Press Enter to save.
'Processing Employer ESI Contribution (Payroll)' has been shared with
