An authorised user can create security levels from the Control Centre and assign the access rights to the users within the account.
To create a security level from the Control Centre
1. Go to the Gateway of Tally > Control Centre > User Management.
2. Press Alt+C in the Security Level field, to view the Security Level Management screen.
3. Enter the Name of security level.
4. Assign the required access rights under Allow the following facilities.
5. Press Ctrl+A to accept.
A security level is created with the necessary rights.
Note: To alter an existing security level, press F8: Sec Level List in the Security Level field. Select the security level and alter the access rights, as required.
'Creating a Security Levels from Control Centre' has been shared with
