https://help.tallysolutions.com/docs/te9rel54/Tax_India/Excise_Importer/Excise_for_Importers.htm
Excise for Importers
Dealers who are engaged in import of excisable goods can register as importers.
Businesses registered as dealers of both imports and indigenous excisable goods can:
●      Obtain a fresh registration as importer.
●      Transfer the closing stock lying in dealer excise units as on 31st March 2014 to importer excise units, to be sold as opening stock under the fresh registration as importer.
●      Maintain separate books of accounts.
●      Generate e-returns with importer registration.
To support the requirements of this Notification, the Excise for Importer feature is introduced with the facility to:
●      Provide registration details of importer.
●      Create godowns with Excise Registration Type as Importer.
●      Transfer stock to importer unit, either manually or using the Import Helper button.
●      Record excise invoices.
●      Generate reports and e-returns.
