Decrease of Output Tax (Madhya Pradesh)
https://help.tallysolutions.com/docs/te9rel54/Tax_India/VAT/Madhya_Pradesh/MP_Decrease_Output_Tax.htm
Tax adjustment required due to decrease in output tax can be recorded by creating a journal voucher with the Nature of adjustment as Decrease of Output Tax.
To create journal voucher for decrease of output tax
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
●      In the Stat Adjustment Details screen,
o      Select the option VAT in the Type of duty/tax field.
o      Select the option Decrease of Output Tax in the Nature of adjustment field.
o      Select the option Tax Deferred in Additional Details field.
o      Press Enter to save and return to voucher screen.
3.     Debit the VAT ledger.
o      Enter the Rate and Assessable Value in the VAT Details screen.
o      Press Enter to return to voucher screen.
4.     Enter the amount in the Debit column.
5.     Credit the ledger grouped under Current Liabilities.
6.     Enter Narration, if required.
7.     Press Enter to save.
