https://help.tallysolutions.com/docs/te9rel54/Data_Management/Splitting_Company_Data_Intro.htm
Splitting Company Data
You can split your company data based on financial years using Tally.ERP 9.
Advantages of splitting data are:
●      Reduced data size.
●      Improved performance/speed of Tally.ERP 9.
●      Data of older financial years will be secure.
●      You can maintain separate company folders for different financial years.
Click on the following links for more:
●      Splitting Company Data
●      Verify Company Data
