https://help.tallysolutions.com/docs/te9rel54/Licensing/FAQs_on_Licensing.htm
Licensing - FAQ
This page lists the some general queries on licensing in Tally.ERP 9 along with specific licensing-related error codes that users may come across. Click the question that you want to view an answer for.
1.     How do I activate Tally.ERP 9 license?
2.     How do I activate a single site account?
3.     How do I activate a multi site account?
4.     How can I surrender Tally.ERP 9 license from the Control Centre?
5.     Is a valid TSS subscription required for filing E-Returns from Tally.ERP9?
6.     How do I resolve licensing issues that I may encounter while in Educational Mode?
7.     How do I surrender Tally.ERP 9 license from Tally.ERP 9?
8.     Can I use more than one Tally.ERP 9 release simultaneously in the same system?
9.     Can I use more than one instance of Tally.ERP 9 in my computer?
10.  Can multiple users access the same single user license at the same time?
11.  Can multiple users access the same multi-user license at the same time?
12.  How do I configure license in client system?
13.  Why should I unlock license?
14.  Where will I get the unlock key?
15.  Do I have to be connected to the Internet all the time to use Tally.ERP 9?
16.  How do I activate a single-user license?
17.  How do I activate multi-user license?
18.  What is multi-site account?
19.  How can I manage all licenses?
20.  Why should I disable antivirus for activating Tally.ERP 9 license?
21.  Should I have a valid TSS subscription to upgrade?
22.  My TSS subscription has expired. How do I upgrade?
23.  How do I add Tally.ERP 9 to the exceptions list in Windows XP Firewall?
24.  How do I activate and add my Tally.ERP 9 license to an existing Account, and manage all licenses using a single e-mail ID?
25.  Do I require administrator rights to perform any licensing operations?
26.  What is an Account?
27.  What is an Account ID?
28.  What is a Site?
29.  What is a Site ID?
30.  What is Tally.NET ID?
31.  What is rental license?
32.  What is Tally.ERP 9 Gold license?
33.  What is Tally.ERP 9 Silver license?
34.  What is a Tally.ERP 9 regular license?
35.  What is Educational Mode?
36.  How do I exclude Tally.exe, TallyAdmin.exe and tallylicserver.exe files from being scanned in Quick Heal Total Security 2013 Antivirus?
37.  How does Silver Edition (Single User) license work from Release 5.x onwards?
38.  What is Tally Gateway Server, and how is it installed?
Error Messages
1.     Error code 39
2.     Error code 52
3.     Error code 401
4.     Error code 402
5.     Error code 403
6.     Error code 404
7.     Error code 405
8.     Error code 406
9.     Error code 407
10.  Error code 408
11.  Error code 409
12.  Error code 410
13.  Error code 411
14.  Error code 412
15.  Error code 801
16.  Error code 802
17.  Error code 803
18.  Error code 804
19.  Error code 805
20.  Error code 806
21.  Error code 807
22.  Error code 808
23.  Error code 809
24.  Error code 2012
25.  Error code 2013
26.  Error code 2015
27.  Error code 2045
28.  Error code 6202
29.  Error code 6203
30.  Error code 6206
31.  Error code 6210
32.  Error code 6235
33.  Error code 6238
34.  Error code 6242
35.  Error code 6248
36.  Error code 6266
37.  Error code 6267
38.  Error code 6401
39.  Error code 6402
40.  Error code 6403
41.  Error code 6404
42.  Error code 6405
43.  Error code 6410
44.  Error code 6413
45.  Error code 6436
46.  Error code 6437
47.  Error code 6439
48.  Error code 6444
49.  Error code 6457
50.  Error code 6464
51.  Error code 6465
52.  Error code 6628
53.  Error code 6629
54.  Silver License with serial number “XXXXXXXXX” is in use on “system name.” Exit all instances of Tally.ERP 9 and try again.
55.  Only one instance of Tally.ERP 9 prior to Release 5.0 can be accessed using the gateway server.
56.  License is in use on Gateway - System Name: Port. Connect Gateway – System Name: Port or reconfigure license path on Gateway – System Name: Port and restart.
57.  Maximum RDP limit exceeded. Close one or more Tally.ERP 9 instance accessed using RDP and try again.
58.  Connect gateway server to internet. License is inactive.
59.  Unknown Status 10060.
60.  To complete this action internet connectivity is required. Connect to internet and try again.
61.  Only Account Administrator or Site Administrator can perform this activity.
