Locations and Godowns
https://help.tallysolutions.com/docs/te9rel54/Creating_Masters/Inventory_Info/Locations_Godowns.htm
Locations/Godowns are places where Stock Items are stored. You can monitor the location-wise movement of stock by creating multiple Godowns.
For example,
Suppose you have three Godowns, where you store the Goods. In Chennai, you have two Godowns and in Bangalore, one Godown.
You can create Godowns as shown below:
Godown
Under
Godown A
Chennai
Godown B
Chennai
Godown C
Bangalore
First you have to Create Chennai and Bangalore locations and then you have to create Godowns under the respective location.
Tally.ERP 9 has a default Godown named Main Location. You can alter Tally's default godown and create a new one. Tally.ERP 9 permits the creation of any number of godowns, under groups and subgroups to match the structure you need.
You can create Locations/Godowns only if Maintain multiple Godowns is enabled in F11: Features > F2: Inventory Features.
●      Go to Gateway of Tally > Inventory Info. > Godowns.
Note: The term Locations is displayed in the Inventory Info. menu, if International is selected under Use Accounting Terminology of in General Configuration (Gateway of Tally > F12:Configure) screen. If India/SAARC is selected, the term Godowns is displayed.
To more, click the links below:
●      Creating Locations/Godowns
●      Displaying and Altering Stock Locations/Godowns
