https://help.tallysolutions.com/docs/te9rel54/Creating_Masters/Accounts_Info/Creating_a_Ledger.htm
Creating Ledgers
You can choose to create a single or multiple ledgers, as per your requirement in Tally.ERP 9.
Creating a Single Ledger
You can create:
●      Cash ledger
●      Profit and loss account ledger
Note: Any number of cash accounts can be created in any other name. For example: petty cash. But only one profit and loss account can be created.
To create a single ledger
●      Go to Gateway of Tally > Accounts Info > Ledgers > Create.
Ledgers can be created in Normal mode or in Advance mode.
Note: Avoid using noise characters in ledger masters as they will not be considered in filtering reports.
Below is the list of noise characters:
Creating Multiple Ledgers
You can create multiple ledgers at a time.
To create multiple ledgers
1.     Go to Gateway of Tally > Accounts Info. > Ledgers > Create (Multiple Ledgers). The Multi Ledger Creation screen is displayed as shown below:
2.     Select the group the List of Groups under which you want to create the ledgers. Selecting All Items in Under Group field lets you select multiple groups.
Note: You can create a new group from this field by pressing Alt+C.
3.     Enter the Opening Balance (balance remaining when you first entered your books on Tally.ERP 9). If you maintain balances bill-by-bill, enter bill details. See Creating a Ledger- Advanced Usage for more details.
4.     Select Dr/Cr for the opening balance to specify debit or credit respectively.
Note: While creating multiple ledgers, the field Cost Centres is set to Yes for revenue accounts and No for non-revenue accounts. The field inventory values affected is set to Yes for sales and purchase accounts and No for the others by default.
Debtor/Creditor Classification
For information on debtor and creditor classification, see Classifying Debtor/Creditor.
