https://help.tallysolutions.com/docs/te9rel54/Advanced_Features/Advanced_Accounting_Features/Altering_a_Scenario.htm
Altering a Scenario
When you don't want a voucher type to affect the scenario anymore, you can modify the existing scenario and remove the voucher type from the Include list.
To alter a scenario
1.     Go to Gateway of Tally > Accounts Info. > Scenario > Alter.
2.     Select the scenario to alter from the List of Scenarios.
3.     Modify the details as required.
4.     Press Enter to save.
