In Tally.ERP 9, you can record a journal voucher to account for the decrease of input tax.
To create journal voucher for CST adjustment
2. Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
3. Select the option VAT in the Type of duty/tax field.
4. Select the option Decrease of Input Tax in the Nature of adjustment field. The Stat Adjustment Details screen appears as shown below:
5. Press Enter to save and return to voucher screen.
6. Debit the CST ledger created under the group Duties & Taxes.
o Enter the Rate, and Assessable Value in the VAT Details screen.
7. Enter the amount in Debit column.
8. Credit the input VAT ledger.
9. Press Enter to save.
'Decreasing Input Tax' has been shared with
