https://help.tallysolutions.com/docs/te9rel54/Payroll/employee_breakup_of_pay_head.htm
Employee Breakup of Pay Head (Payroll)
You can view the Summary employee-wise breakup of the Computation for the required Pay Head from the Payroll Reports or Statutory Reports.
To view employee-wise breakup
1.     Go to Gateway of Tally > Display > Payroll Reports > Statutory Reports > Summary.
Or
2.     Go to Gateway of Tally > Display > Statutory Reports > Payroll Reports > Summary.
3.     Press Enter on the required Pay Head Type.
4.     Press Enter on the required Pay Head.
The user can drill down to a corresponding Employee Voucher from the above report.
Button options in the Employee Breakup of Pay Head
F2: Period
Click F2: Period to change the selected period.
F12: Configure
Click F12: Configure show/hide the Employee Number.
