Input Tax Adjustment for Purchases From URDs
https://help.tallysolutions.com/docs/te9rel54/Tax_India/VAT/BR_Input_Tax_Adj_Pur_Frm_URD.htm
In Tally.ERP 9, you can create a journal voucher to account for tax credit on purchase from unregistered dealers.
To create journal voucher for tax credit on purchase from URDs
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
●      In the Stat Adjustment Details screen,
o      Select the option VAT in the Type of duty/tax field.
o      Select the option Input Tax Adjustment for Purchases From URDs in the Nature of adjustment field.
o      Press Enter to save and return to voucher screen.
3.     Debit the VAT ledger.
o      Enter the Rate and Assessable Value in the VAT Details screen.
o      Press Enter to return to voucher screen.
4.     Enter the amount in the Debit column.
5.     Credit the ledger grouped under Current Assets.
6.     Enter Narration, if required.
7.     Press Enter to save.
