https://help.tallysolutions.com/docs/te9rel54/Auditor_Edition/India/Statutory_Audit/Identifying_Related_Parties.htm
Identifying Related Parties (India)
Those Ledgers which are marked by the Auditor as Related Party will only appear in the Related Party Transactions report.
To identify/mark a Ledger as Related Party
1.     Go to Gateway of Tally > Audit & Compliance > Audit & Analysis > Related Party Transactions.
2.     Click on Ctrl+F9: Master Config or press Ctrl+F9.
3.     Select Related Party and press Enter.
4.     Select the required Ledger(s) using Spacebar in the Related Party Configuration screen.
o      Click F5: Update or press F5 to view Related Party Details screen to mark the selected Ledger as Related Parties.
o      Related Party Details screen is displayed.
o      Press Enter to save the Related Party Configurations.
Note: Follow the same steps to unmark a Party which is wrongly identified as Related Party.
o      Press Escape to view the Related Party Transactions report.
Ctrl+W: Audit Wkg Paper
To view the Audit Working Paper during Auditing, click Ctrl+W: Audit Wkg Paper or press Ctrl+W. The details displayed in Audit Working Paper will be relevant to report from where it is triggered. This report displays the details of Configuration of Periodic Ledgers.
