https://help.tallysolutions.com/docs/te9rel54/Tax_International/Kenya_VAT/Get_Startd_with_VAT.htm
Getting Started with VAT - Kenya
The master experience has been enhanced such that you can configure statutory details and get started with  the transactions within no time.
The enhancements in masters and the steps to configure masters are explained below:
Configuration based behaviour
It is now possible to create a tax ledger under current assets or current liabilities, and the ledger can now exhibit the properties of a ledger grouped under duties and taxes.
Similarly, you can create a party ledger under loans and liabilities.
The change in behaviour will reflect for tax calculation, but doesn't have an effect on the reports.
Appropriation of ledgers
You can now appropriate the ledger to the cost of the item from the ledger master screen, instead of the group.
Default accounting entries
For any voucher type, you can now define default accounting entries. This will populate information for the specified ledger, every time a transaction is recorded using this voucher type.
For any voucher type, now you can define default accounting entries. This will populate the ledgers by default, every time a transaction is recorded using this voucher type.
