https://help.tallysolutions.com/docs/te9rel54/Payroll/employee_vouchers.htm
Employee Vouchers (Payroll)
You can view the Employee Vouchers from Payroll Reports or Statutory Reports under Display.
To view the Employee Vouchers
1.     Go to Gateway of Tally > Display > Payroll Reports > Statutory Reports > Summary.
     Or
2.     Go to Gateway of Tally > Display > Statutory Reports > Payroll Reports > Summary.
3.     Press Enter on the required Pay Head Type.
4.     Press Enter on the required Pay Head.
5.     Press Enter on the required Employee Name.
6.     Click F1: Detailed.
The user can drill down to a corresponding Payroll/Payment Vouchers from the above report.
