Reversal of input tax can be recorded by creating a journal voucher. Use Refund of Input Tax as the Nature of Adjustment.
To create journal voucher to account for refund order
2. Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
In the Stat Adjustment Details screen,
o Select the option Refund of Input Tax in the Nature of adjustment field.
o Select the option Refund Order in Additional Details field.
o Press Enter to save and return to voucher screen.
3. Debit the VAT ledger.
o Enter the Rate and Assessable Value in the VAT Details screen.
4. Enter the amount in the Debit column.
5. Credit the ledger grouped under Current Assets.
6. Enter Narration, if required.
7. Press Enter to save.
'Refund of Input Tax (Madhya Pradesh)' has been shared with
