https://help.tallysolutions.com/docs/te9rel54/Job_Work/JI_Stock_Ageing_Analysis.htm
Stock Ageing Analysis Report (Job Work In)
Stock Ageing Analysis report displays the details of period (i.e. for how long) the Principal manufacturers stock is lying with the Job worker.
To view the stock Ageing Analysis reports
1.     Go to Gateway of Tally > Display > Job Work In Reports > Stock > Ageing Analysis
2.     In Select Item screen select the stock group for which the Ageing Analysis report to be viewed.
The Stock Ageing Analysis report is displayed as shown:
