https://help.tallysolutions.com/docs/te9rel54/Data_Management/DM_Upload_Reports_Generated.htm
Uploading Reports from Tally.ERP 9 to a Web Page
You can upload your financial reports to your website directly from Tally.ERP 9.
To upload reports from Tally.ERP 9 to a web page
1.     Click O: Upload in the required report.
2.     Select Web Page (HTTP/HTTPS) in the field Upload to.
3.     Enter the URL.
4.     Set the option Secure Server? to Yes, if required.
5.     Enter User Name.
6.     Enter Password.
Note: Reports can be uploaded without entering a user name and password if the web page server accepts anonymous connections.
7.     Select the required Format.
8.     Enable, disable or select additional configurations if required.
The upload report screen appears as shown below:
9.     Press Enter to upload the report to the web page.
See Also
Uploading Reports from Tally.ERP 9 to an FTP Location
Uploading Vouchers from Tally.ERP 9 to a Web Page
Uploading Vouchers from Tally.ERP 9 to an FTP Location
