https://help.tallysolutions.com/docs/te9rel54/Voucher_Entry/Order_Processing/Enabling_Order_Processing.htm
Enabling Order Processing
To enable purchase order, sales order, and job order processing in Tally.ERP 9, you have to activate the required features in F11: Features (F2: Inventory Features).
Enable the following features in the Order Processing section:
●     Enable purchase order processing
●      Allow Sales Order Processing
●      Enable job order processing.
Note: When Enable job order processing is set to Yes, the options Maintain multiple Godowns and Use material in and out vouchers get enabled automatically.
