You can record a journal voucher to record the tax incurred on purchase from an unregistered dealer.
To create tax liability on purchase from unregistered dealers
2. Click J: Stat Adjustment.
o Select VAT as Type of duty/tax.
o Select the option Tax on URD Purchase in the Nature of adjustment field, as shown below:.
o Press Enter to save and return to voucher screen.
3. Debit the ledger created under the group Indirect Expenses and enter the amount in Debit column.
4. Credit the purchase tax/VAT ledger created under the group Duties & Taxes.
o Enter the Rate and Assessable Value of the item purchased in the VAT Details screen. The VAT Details screen appears as shown below:
o Enter the Commodity name and Commodity Code.
5. Enter Narration, if any.
6. Press Enter to save.
'Tax on URD Purchase (Tamil Nadu)' has been shared with
