Accounting masters can be enabled for job costing by setting the option Cost Centres are applicable? to Yes.
For example, to account for project inspection charges, create a ledger under Indirect Expenses as shown below:
Note: The option Cost Centres are applicable? will be available only if the option Provide Advanced Information in Masters is enabled in the Master Configuration (F12: Configure) screen.
'Accounting Ledgers' has been shared with
