To record a transaction with decreased input tax value, you can create a journal voucher with the necessary Stat Adjustments, debit your CST ledger, and credit the input VAT ledger.
To create journal voucher for decreasing input tax
2. Click J: Stat Adjustment to enable required options in Stat Payment Details screen. In the Stat Adjustment Details screen,
o Select the option Decrease of Input Tax in the Nature of adjustment field.
o Select the option Against CST in the Additional Details field.
o Press Enter to save and return to voucher screen.
3. Debit the CST ledger created under the group Duties & Taxes.
o Enter the Rate and Assessable Value in the VAT Details screen.
4. Enter the amount in Debit column.
5. Credit the input VAT ledger created under the group Current Assets.
6. Press Enter to save.
'Recording Decrease in Input Tax (Delhi)' has been shared with
