You can create a duty ledger for accounting for TCS and also specify the nature of goods.
To create a TCS duty ledger
1. Go to Gateway of Tally > Accounts Info. > Ledgers > Create.
2. Enter the Name
3. Select Duties and Taxes as the group name in the Under field.
4. Select TCS as the Type of Duty/Tax.
5. Select a Nature of Goods/Contract/License/Lease from the List of Nature of Goods.
6. Press Enter.
7. Press Ctrl + A to save the details.
'Creating TCS Duty Ledger' has been shared with
