https://help.tallysolutions.com/docs/te9rel54/Payroll/Create_Statutory_Pay_Heads.htm
Creating Statutory Pay Heads
Statutory Pay Head Type
The Statutory Pay Head Type field is enabled when you choose one of the following Pay Head Types:
●      Employees' Statutory Deductions
●      Employer's Statutory Contributions
●      Employer's Other Charges.
The default Statutory Pay Head Types in Tally.ERP 9 are:
●      Employee State Insurance
●      PF Account (A/c No. 1)
●      EPS Account (A/c No. 10)
●      Professional Tax
●      Income Tax
●      Voluntary PF (A/c No. 1)
●      Admin Charges (A/c No. 2)
●      EDLI Admin Charges (A/c No. 22)
●      EDLI Contribution (A/c No. 21)
●      National Pension Scheme (Tier - I)
●      National Pension Scheme (Tier - II)
Note: Statutory Pay Head Type will appear only when the Payroll Statutory Features are enabled.
Use for Gratuity
Set this parameter to Yes for those pay head components that are used for calculating gratuity (For example, Basic Pay and DA).
Calculation Types
The value of a pay head component is derived based on the Calculation Type chosen. The List of Calculation types includes:
●      As Computed Value
●      As User Defined Value
●      Flat Rate
●      On Attendance
●      On Production
Note: The formula defined in Calculation Type will be used for computation only while using payroll Auto Fill feature in the Payroll Voucher. The formula is not applicable when you create the payroll voucher in the manual entry mode.
Flat Rate
Use Flat Rate when the value of the pay head is a fixed amount for a period. If you choose this, pro-rata calculation is not applicable.
For example,
●      Conveyance Allowance of 800 per month.
●      Fixed Loan Installment deduction amount.
On Attendance
Use On Attendance type to calculate the pay head component based on the attendance details of employees.  You can record attendance as positive days (Present) or loss of pay (Absent) type.
For example,
●      Basic salary is calculated on attendance
Attendance/Leave with pay
●      Select Present to calculate the pay head value.
Leave without Pay
●      Select Not Applicable in the Attendance/Leave with Pay field, and select Absent in the Leave without Pay field to calculate the pay head value.
On Production
Use On Production to calculate the pay head value based on the production/work done. You can enter the production data in the  Attendance voucher against the Production type. For example, Overtime.
As Computed Value
Use the As Computed Value if the pay head value is dependent on another pay component.
You can define a pay component by:
●      Specifying a formula
●      Calculating the pay head based on the
●      Current sub-total
●      Current earning
●      Total deduction
You can define the slab either by percentage or value, or a combination of both.
For example, HRA as 40% of Basic Salary
Computation Info
Compute On
●      On Current Deductions Total – Used when the value of a pay head depends upon the total of the deduction pay heads already defined.
●      On Current Earnings Total – Used when the value of a pay head depends upon the total earnings pay heads already defined.
●      On Current Sub Total – This Used when the value of a pay head depends upon the net total of earnings and deductions already defined.
●      On Specified Formula – Used when the pay head value is computed on the basis of value of one or more pay heads already defined in the pay structure. Tally.ERP 9 allows addition, subtraction, multiplication and also division of pay heads already defined in the pay structure. For example: HRA is computed on 40% of the basic salary.
Effective From
By default, the Effective From date is considered as the start date of the financial year in which the Pay Head is created. You can define any revision in pay computation for a given pay head by modifying the Effective From date.
Amount Greater Than
If you use multiple slabs for calculating any pay head, enter the start value for each slab in this field. By default, this field is skipped, and assumed to be 0 for the first slab.
Amount Upto
The upper limit for each slab is provided in this field.
Slab Type
●      Percentage: This slab rate is applicable when the amount is stated as a percentage of a whole.
●      Value: This slab rate is applicable when the amount is stated as absolute value.
Value Basis
Value Basis for each slab is provided in this field, which can be either an Amount or Percentage based on the Slab Type.
Note: All new Pay Heads appear under the List of Ledgers in the default Accounting reports.
As User defined Value
You can use the As User defined Value field to manually enter the value at the time of processing the salary. This calculation type is applicable when the value of pay is not fixed, and does not depend on any pay component. You can also choose a calculation period, as is applicable.
For example,
●      Incentives
●      Variable Salary
Calculation Period
Calculation Period refers to the periodicity of pay head calculation. Four pre-defined calculation periods are available in Tally.ERP 9:
●      Days
●      Fortnights
●      Months
●      Weeks
Per day Calculation Basis
As per Calendar Period
As per Calendar Period refers to calculation based on a calendar month period. For instance, if the payroll process is carried out for the month of March, the attendance records will be entered for 31 days.
User Defined
User Defined refers to a consistent payroll period entered by the user, irrespective of calendar month. For instance, if an employee’s salary is based on a standard month of 30 days irrespective of the calendar month, you can select User Defined as the Calculation Basis, and define the periodicity of the specified period or month.
User Defined Calendar Type
You can use the User Defined Calendar Type option to select user defined working/calendar days for every Calculation Period.
For example, you can enter the total number of working days after reducing the Saturdays,  Sundays and holidays, if any, as  required.
Rounding Method
The four methods of rounding off available while calculating pay heads are:
●      Not Applicable: The decimal points are taken into consideration, and the amount will not be rounded off.
●      Downward Rounding: The amount is rounded off to the nearest lower whole number.
●      Normal Rounding: The amount is rounded off to the nearest whole number.
●      Upward Rounding: The amount is rounded off to the nearest higher whole number.
