https://help.tallysolutions.com/docs/te9rel54/Voucher_Entry/Advanced_Voucher_Entry/Adv_Voucher_Entry_in_Tally.htm
Introduction to Advanced Voucher Entry in Tally.ERP 9
Advanced usage in voucher entry involves using more features of Tally.ERP 9. This would mean entering of data in various pop-up and sub-screens depending on the context and configuration (both F12 and F11) settings.
Click the following links for more:
●      Using Additional Cost of Purchase
●      Using Inventory Allocations
●      Using Tracking Numbers
●      Using Zero Valued Entries
●      Using different Actual and Billed Quantities
●      Using Batchwise details
●      Using Mfg. and expiry dates
●      Using Cost Categories and Cost Centres
●      Using Cost Centre Class
●      Using Multi-currency
