https://help.tallysolutions.com/docs/te9rel54/Maintaining_Company_Data/F11_Features/F3_Statutory_Taxation.htm
Statutory and Taxation
Tally.ERP 9 supports the various taxes applicable in India. You can maintain accurate books of accounts and generate error-free returns by detecting the missing information in the transactions, if any, and correct them before filing returns.
You can use statutory and taxation features in Tally.ERP 9 by enabling the required options in the Company Operations Alteration screen.
To enable statutory and taxation features
1.     Go to Gateway of Tally > F11: Features > F3: Statutory.
2.     Enable the required options in the Company Operation Alteration screen as shown below:
See also
Enabling Excise
Enabling Value Added Tax
Enabling Service Tax
Enabling Tax Deducted at Source
Enabling Tax Collected at Source
