Recording Decrease in Output Tax - TDS Adjustment (Assam)
https://help.tallysolutions.com/docs/te9rel54/Tax_India/VAT/Assam/AS_Decr_Output_tax.htm
Decrease in output tax can be adjusted by creating a journal for TDS adjustment.
To create a journal voucher for TDS adjustment
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment to enable the required options in the Stat Adjustment Details screen.
●      In the Stat Adjustment Details screen,
o      Select Type of duty/tax as VAT.
o      Select Decrease of Output Tax, as the Nature of adjustment.
o      Select the TDS Adjustment in Additional Details section.
Note: Based on the selection made for Nature of Adjustments, the Additional Details option will appear or disappear.
o      Press Ctrl+A to return to the voucher.
3.     Debit the VAT ledger created under the group Duties & Taxes.
o      Enter the Rate and Assessable Value in the VAT Details screen.
o      Press Enter to return to voucher screen.
4.     Enter the amount in Debit column.
5.     Credit the ledger created under the group Current Assets.
6.     Press Enter to save.
