https://help.tallysolutions.com/docs/te9rel54/Tax_India/VAT/Delhi/Decrease_of_Output_Tax.htm
Recording Decrease in Output Tax (Delhi)
To record a transaction with decreased output tax value, you can create a journal voucher with the necessary Stat Adjustments, debit your VAT ledger, and credit the relevant ledger under Current Assets.
To create journal voucher for decreasing output tax in lieu TDS paid
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment to enable required options in Stat Payment Details screen. In the Stat Adjustment Details screen,
o      Select the option VAT in the Type of duty/tax field.
o      Select the option Decrease of Output Tax in the Nature of adjustment field.
o      Select the option TDS Adjustments in the Additional Details field.
o      Press Enter to save and return to voucher screen.
3.     Debit the VAT ledger created under the group Duties & Taxes.
o      Enter the Rate and Assessable Value in the VAT Details screen.
o      Press Enter to return to voucher screen.
4.     Enter the amount in Debit column.
5.     Credit the ledger created under the group Current Assets.
6.     Press Enter to save.
