https://help.tallysolutions.com/docs/te9rel54/Creating_Masters/Inventory_Info/Display_Alter_Stock_Location_Godown.htm
Displaying and Altering a Stock Location or Godown
You can display/alter the Godowns in single and multiple modes. It is similar to Displaying/Altering Stock Groups in single and multiple modes. Refer Displaying/Altering Stock Groups for more details.
To display a single stock Location/Godown
●      Go to Gateway of Tally > Inventory Info. > Locations/Godowns > Display (under Single Location/Godown).
To display multiple stock Locations/Godowns at a time
●      Go to Gateway of Tally > Inventory Info. > Locations/Godowns > Display (under Multiple Locations/Godowns).
To alter a single stock Location/Godown
●      Go to Gateway of Tally > Inventory Info. > Locations/Godowns > Alter (under Single Location/Godown).
To alter multiple stock Locations/Godowns at a time
●      Go to Gateway of Tally > Inventory Info. > Locations/Godowns > Alter (under Multiple Locations/Godowns).
You can delete a Godown/ location via Single Godown/Location Alter by pressing [Alt]+[D]. However, you cannot delete a Godown/location with sub-locations. The lower levels must be deleted first.
