https://help.tallysolutions.com/docs/te9rel54/Creating_Masters/Accounts_Info/Pre-defined_Voucher_Types_in_Tally.htm
Pre-Defined Voucher Types
For recording transactions a list of pre-defined voucher types are made available.
To view the pre-defined voucher types
1.     Go to Gateway of Tally > Display > List of Accounts.
2.      Press Ctrl+V to display the voucher types. The List of Voucher Types screen appears as shown below:
Alternatively, go to Gateway of Tally > Accounts info / Inventory Info > Voucher types > Alter.
The Voucher Type list appears as shown below:
Alter a Pre-defined Voucher Type
A pre-defined voucher type can be altered to customise it. For example, to control their numbers.
To alter a voucher type
      Go to Gateway of Tally > Accounts info. / Inventory Info. > Voucher types > Alter. The Voucher Type Alteration screen appears as shown below:
