https://help.tallysolutions.com/docs/te9rel54/Creating_Masters/Accounts_Info/Create_Ledger_with_Advanced_Usage.htm
Creating Ledgers with Advanced Entries
Your F11: Features and F12: Configure settings for a company defines the ledger creation.
To create a ledger in the advanced mode
1.     Enable the following features in F1:Account under F11:Features:
●      Allow multi-currency.
●      Maintain bill-wise details
●      Maintain cost centres
●      Activate interest calculation
2.     Enable F12: Configure option Allow advanced entries in masters in the Ledger Configuration screen.
All options relevant to the features enabled will be available in the master creation/ alteration screens as shown below:
Note: The field Description will appear in the Ledger Creation screen only if the option Add description for ledger accounts is enabled in the Ledger Configuration screen.
