https://help.tallysolutions.com/docs/te9rel54/Banking/chq_printing_orientation.htm
Changing Cheque Printing Orientation
The orientation of a cheque can be changed, as required, by altering your bank ledger and setting the option to change the print configuration.
To change the orientation of a cheque
1.     Go to Gateway of Tally > Accounts Info. > Ledgers > Alter.
2.     Select the bank ledger from the List of Ledgers.
3.     In the Ledger Alteration screen, under Bank Configuration, enable Set cheque print configuration?
4.     Select the cheque format from the List of Cheque Formats, and press Enter.
The Cheque Dimensions page appears.
5.     Press Alt+P to view the Printing page.
6.     Click N: Orientation to view the Cheque Printing Orientation page.
7.     Set Cheque Printing Orientation, as required.
The Cheque Printing Orientation page appears as shown below:
8.     Press Ctrl+A to accept.
Now, you can print the cheque with the required orientation.
