https://help.tallysolutions.com/docs/te9rel54/Tax_India/TDS/TDS_Ledger.htm
Creating TDS Ledger
A TDS ledger is used for recording duties in TDS-related transactions.
To create a TDS tax ledger
1.     Go to Gateway of Tally > Accounts Info. > Ledgers > Create.
2.     Enter the Name.
3.     Select Duties and Taxes as the group name in the Under field.
4.     Select TDS as the Type of Duty/Tax.
5.     Select a Nature of Payment  from the List of Nature of Payments.
6.     Press Enter.
7.     Press Ctrl+A to save the details.
