https://help.tallysolutions.com/docs/te9rel54/Voucher_Entry/Accounting_Vouchers/Creating_a_Journal_Entry.htm
Recording a Journal Entry
Journal Vouchers are used to adjust the debit and credit amounts without involving the cash or bank accounts. Hence, they are referred to as adjustment entries.
To pass a Journal Voucher,
●      Go to Gateway of Tally > Accounting Vouchers.
●      Click on F7: Journal on the Button Bar or press F7.
For example, there may be entries made for interest accrued or interest due. If you have to receive Interest from a party, the same can be entered using Journal Voucher.
●      Debit the Party.
●      Credit the Interest Receivable Account.
The Journal entry is displayed as shown:
Special Keys for Voucher Narration Field:
●      ALT+R: Recalls the Last narration saved for the first ledger in the voucher, irrespective of the voucher type.
●      CTRL+R: Recalls the Last narration saved for a specific voucher type, irrespective of the ledger.
See also
Allowing Cash Accounts in Journals
