https://help.tallysolutions.com/docs/te9rel54/Tax_India/VAT/Rajasthan/RJ_Decr_Input_Tax.htm
Decrease in Input Tax (Rajasthan)
You can create a journal voucher for CST adjustment with Decrease of Input Tax as  the nature of adjustment.
To create journal voucher for CST adjustment
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
3.     Debit the CST ledger created under the group Duties & Taxes.
o      Enter the Rate, Assessable Value and Schedule Serial No., and select the Schedule Name in the VAT Details screen.
o      Press Enter to return to voucher screen.
4.     Enter the amount in Debit column.
5.     Credit the input VAT ledger.
6.     Press Enter to save.
