https://help.tallysolutions.com/docs/te9rel54/Job_Work/JI_Order_Outstandings.htm
Order Outstandings Report (Job Work In)
Order Outstandings report display the details of all the Job work In orders raised on the Principal Manufacturer which are pending.
To view the Order Outstandings report
●      Go to Gateway of Tally > Display > Job Work In Reports > Order Outstandings.
The Order Outstandings reports are:
●      Orders
●      Components
