https://help.tallysolutions.com/docs/te9rel54/Data_Management/DM_Outward_Connectivity.htm
Outward Connectivity
Using the outward connectivity feature of Tally.ERP 9, you can transfer data between programs without additional programming. The user can transfer data from Tally.ERP 9 to Microsoft Word or Excel.
Using the Outward Connectivity feature you can:
●      Generate Labels from ledger addresses stored in Tally.ERP 9
●      Create templates for reports, forms and plug in up-to-date data from Tally.ERP 9.
To know more click the link: Tally.ERP 9 ODBC with Microsoft Excel
