Tax adjustment required due to decrease in output tax can be recorded by creating a journal voucher with the Nature of adjustment as Decrease of Output Tax.
To create journal voucher for decrease of output tax
2. Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o Select the option Decrease of Output Tax in the Nature of adjustment field.
o Select the option Tax Deferred in Additional Details field.
o Press Enter to save and return to voucher screen.
3. Debit the VAT ledger.
o Enter the Rate and Assessable Value in the VAT Details screen.
4. Enter the amount in the Debit column.
5. Credit the ledger grouped under Current Liabilities.
6. Set the option Provide VAT Details to Yes and enter the From and To dates, else retain it as No.
7. Enter Narration, if required. The journal voucher appears as shown below:
8. Press Enter to save.
'Decrease of Output Tax' has been shared with
