Enabling MCA Reports is a simple process.
To enable MCA Reports Feature in Tally.ERP 9, follow the steps given below:
Go to Gateway of Tally > F11: Features > Statutory & Taxation Features
Set the option Enable MCA Reports to Yes
On enabling MCA Reports, in Statutory Reports menu a new option MCA Reports will be displayed.
This menu bifurcates MCA Reports into:
'Enabling XBRL in Tally.ERP 9' has been shared with
