The Payroll Info. menu allows to create various payroll masters required for computing earnings and deductions for employees.
Go to Gateway of Tally > Payroll Info.
Note: The Employee Categories option will be available only when the More than one Payroll / Cost Category option is set to Yes in F11: Accounting Features screen.
Payroll Info:
'Payroll Info Menu (Payroll)' has been shared with
