This feature enables you to set the various Accounting Features required for transaction entries.
Go to Gateway of Tally > F11: Features > F1: Accounting Features
This option has a significant effect on the Balance Sheet and Profit & Loss Account. If set to Yes, it extracts the stock/inventory balance figures from the inventory records and provides a drill down to the Stock registers from the Balance Sheet.
If set to No, it ignores the inventory books figures and picks up manually entered closing stock balances from the ledger account created. This facilitates the maintaining of accounts and inventory separately.
Stock records often contain compensating errors caused by wrong allocation to items. This feature enables finalisation of financial books without waiting for the reconciliation of stocks.
By Default, this option is set to No.
If set to Yes – Tally.ERP 9 displays Income & Expenses A/c instead of Profit & Loss A/c in the Gateway of Tally.ERP 9 Menu. Income and Expenditure statement generally used for Non-Trading accounts and Profit & Loss a/c are used for trading accounts.
By Default, this option is No.
Set this option to Yes, if you want to create multiple currencies and the Menu Currencies is displayed in Gateway of Tally > Accounts Info. menu.
The Bill-wise facility is made functional by setting this option to Yes. By activating the Billwise feature, the ledger masters under Sundry Debtors and Sundry Creditors automatically displays an additional option called Maintain balances bill-by-bill. On setting this option to Yes, an additional option Default Credit Period is displayed.
When you enter details of sales and purchases with the Bill-wise option activated, Tally.ERP 9 prompts you to identify the invoice with an appropriate reference number. The reference can then be used to allocate payments to the correct invoice to maintain an accurate account of outstanding.
If you want to maintain bill wise details for Non-Trading Accounts also, set this option to Yes. Bill wise Details for Non-Trading Accounts is useful in those cases where one needs to track either an installment to be paid or a loan amount to be received over a certain period of time.
Set this option to Yes to enable Tally.ERP 9 to calculate interest automatically based on the interest rate and style of calculation specified. Enabling this option allows interest calculation on outstanding balances for any ledger account or on each invoice for the period it is outstanding completely or partly.
The advanced parameters are useful when interest rates change from time to time. Set this option to Yes to enable this function.
Set this option to Yes if you want to maintain Payroll information on Tally.ERP 9 for the selected company .
A Cost Centre can be defined as a unit of an organization to which transactions can be posted. When only costs or expenses are allocated to these units, they are referred to as Cost Centres. The Cost Centre feature is activated by setting this option to Yes.
Set this option to Yes to track all income and expenses for a Job/Project.
Set this option to Yes to create more than one Payroll or Cost Category.
Set this option to Yes to define Cost Centre Allocations. Refer Cost Centres and Cost Categories for details.
Set this option to Yes to display the opening balance in Cost Centre Report for the cost centres which are allocated to the Ledgers, grouped under Income and Expenses Group.
Set this option to Yes, to create Sales and Purchase vouchers in the invoice format. The advantage of using the invoice format for sales invoice entry is that it enables automatic calculations of Duties and Taxes accounts.
Set this option to Yes, to enable voucher class option in purchase voucher type.
The Debit Note and Credit Note voucher types are made available only if this feature is set to Yes.
Set this option to Yes to create Credit Notes in Invoice Mode.
Set this option to Yes to create Debit Notes in Invoice Mode.
Set this option to Yes, to create multiple budgets. The Budgets menu option is displayed in Gateway of Tally > Masters Info. > Accounts Info. menu.
Setting this option to Yes displays the Scenario option in Accounts Info menu. You will now be able to create and alter Scenarios. You can enter the Reversing Journal and make it Optional, so that the entries do not to affect the books.
Set this option to Yes, to enable Cheque Printing. Refer Cheque Printing for details.
Alter Banking Features
Set this option to Yes to alter features with respect to Banking. Refer Banking Features for details.
Set this option to Yes, to allow Zero valued entries in vouchers.
Set this option to Yes, to maintain multiple mailing details for your company and ledgers. Refer Multi Address for details.
If this option is set to Yes, Tally.ERP 9 will allow you to alter the Create/Alter Address Types.
This option allows to print the company's logo on the selected vouchers, reports and invoices.
Set this option to Yes, the Company Logo screen appears. Specify the path of the logo image file under Location of Logo (E.g. C:\Tally.ERP9\CompLogo.bmp). The Company's logo is printed on the top left of the respective voucher, report or an invoice.
Note: It is essential that the logo is saved as a Bitmap or JPEG image file and resides in the path specified by you. Ensure that the extensions .bmp /.jpg is also specified while providing the location of logo.
The recommended size for logo image is 96 x 80 (Width x Height) pixels.
You can toggle between the Accounts, Inventory, Statutory, Tally.NET and the Tax Audit features screen using F1, F2, F3, F4 and F5 keys or by using the options on the Button Bar respectively.
'F1_Accounting Features' has been shared with
