Statutory Reports are reports required in government prescribed formats for the purpose of filing returns. TCS statutory reports in Tally.ERP 9 are dynamically generated; Print and file a report. An e-Filing TCS return is supported using the export feature.
To view Statutory Reports:
Go to Gateway of Tally > Display > Statutory Reports > TCS Reports
TCS Reports menu displays the following options.
'Statutory Reports' has been shared with
