https://help.tallysolutions.com/docs/te9rel49/03_VOUCHER_ENTRY_IN_TALLY/01_Accounting_Vouchers/Journal_Entry.htm
Journal Entry
Journal Vouchers are used to adjust the debit and credit amounts without involving the cash or bank accounts. Hence, they are referred to as adjustment entries.
More :
Creating Journal Entry
Allowing Cash Accounts in Journals
