https://help.tallysolutions.com/docs/te9rel49/03_VOUCHER_ENTRY_IN_TALLY/04_Order_Processing/Enabling_Order_Processing.htm
Enabling Order Processing
To enable Purchase Order, Sales Order and Job Order Processing in Tally.ERP 9, activate the following in F11: Features (F2: Inventory Features)
Set Allow Purchase Order Processing, Allow Sales Order Processing and Job Order Processing to Yes in the Order Processing section.
Note: When Allow Job Order Processing is set to Yes, the options Maintain Multiple Godowns and Use Material In/Out get enabled automatically.
