With a major Technological enhancement in Tally.ERP 9, data Synchronisation is available through Tally.NET server. To synchronize data across Server and Client, it is essential to connect to Tally.NET at Server end.
To commence the synchronisation process using Tally.NET server, execute the following steps as shown:
Configure Server for Synchronisation
Configure Tally.NET on Server
Connect Server Company to Tally.NET
Configure Client for Synchronisation
Create Sync Rule on Client
Activate Rule from Client
Activate/Enable Sync Rule on Server
Note: In the Tally.NET framework it is essential to connect the Client and the Server to Tally.NET in order to Synchronise data.
'Synchronization Using Tally.Net Server' has been shared with
